Itens collecting at the same time
  • gibbix
    • Oct 2014
    I've got an external check which returns me an information like:
    OK 1 0 1 4
    And each of this information is an item.
    Like:
    Plugin check : OK
    In use: 1
    Problems: 0
    But I'm executing the external check with a parameter like:
    check[{HOST.IP},1] - this returns me status.
    The only problem is that i need all this information collected at the same time.
    Is there a way I can collect all at the same time and then separe them as itens? Or force all the collects to be at the same item for a template? All the information is complementary, and I need them to be collected at the same time..
    Can anyone help?
  • BDiE8VNy
    • Apr 2010
    • 680
    How about using Zabbix trapper items?
    You could send multiple values in a bulk via Zabbix sender executed by your external check.
    The value returned by your external check could then possibly be replaced by a status/return code whether everything worked well.
    One could also think of executing the respective script that collects/sends the data by Cron instead by Zabbix.
    • gibbix
      • Oct 2014
      Good ideas, I liked the idea of sending it with zabbix_sender. It worked well, but I didn't want to be a "hostage" of zabbix agent. I would like to send/collect the information without having to install the agent on the host.
      Could u think another possibility of doing that?
      • BDiE8VNy
        • Apr 2010
        • 680
        As mentioned before by executing a custom script that collects the data and sends it to Zabbix server via Zabbix sender.
        When you even want to get rid of zabbix_sender, then take a look at the Zabbix sender protocol and feed it by yourself.
        Zabbix sender protocol implementation in Perl
        Zabbix sender protocol implementation in Ruby
        Zabbix sender protocol implementation in Java
