Host availability widget
  • netum
    • Sep 2019
    • 11
    Hello Zabbix community,
    I need to fusion agent zabbix and SNMP in one entry.
    If it's not possible is there a way to rename "agent zabbix" and "SNMP" ?
    Netum
  • Hamardaban
    • May 2019
    • 2714
    The short answer is no. More expanded are the built-in strings . If you are not satisfied with this display - try using another. If you are not satisfied with Zabbix visualization capabilities - install and use grafana.
    • Atsushi
      • Aug 2013
      • 2028
      You may be able to change it by changing the translation settings. It is necessary to change the language setting file used and reload it. Note, however, that other screens that use the same string will change as well.
      Are you using a French setting? You can change it by following the steps below.
      1. Get tarball of source file
      2. Expand tarball
      3. Copy shell script
      4. Copy French language file
      5. Edit French language file
      6. Generate mo file
      7. Restart web server or php-fpm
      Or you can change the PHP code.
      /usr/share/zabbix/include/classes/widgets/views/widget.hostavail.form.view.php
      However, it is not recommended to change the source code because it will not be able to support Zabbix version upgrade.
      • netum
        • Sep 2019
        • 11
        2. Expand tarball
        6. Generate mo file
        thank you for your answer
        Yes I using french language
        So I tryed to edit widget.hostavail.form.view.php
        and after a reboot nothing happens :c
        • Atsushi
          • Aug 2013
          • 2028
          It will not be reflected by that change method. The notation of that part of the original is for processing the translated character string, so to avoid performing the translation process, it is necessary to take a method of directly specifying the character string. There seem to be two files to change.
          # diff widget.hostavail.form.view.php.org widget.hostavail.form.view.php
          44,45c44,45
          <               INTERFACE_TYPE_AGENT => _('Zabbix agent'),
          <               INTERFACE_TYPE_SNMP => _('SNMP'),
          >               INTERFACE_TYPE_AGENT => 'Serveur Windows et Linux',
          >               INTERFACE_TYPE_SNMP => 'Caméras',
          /usr/share/zabbix/app/views/monitoring.widget.hostavail.view.php
          # diff monitoring.widget.hostavail.view.php.org monitoring.widget.hostavail.view.php
          23,24c23,24
          • netum
            • Sep 2019
            • 11
            44,45c44,45
            23,24c23,24
            Thank you ! it's work
            Happy new year !
