ICMPPing from agent to any IP
  • Wolkenstein
    • Dec 2019
    i am currently trying to monitor my network quality with icmppingloss and icmppingsec.
    For this purpose an agent should ping different IPs outside the network. This works fine with webservers, but now I need more than just http.
    Optionally, I can also imagine pinging the agent located in the network to be monitored from different points outside the network.
    Does anyone know a solution without externalscripts?
    I use Zabbix 4.0.15
  • Hamardaban
    • May 2019
    • 2714
    Let's be clear: 1) are you talking about the icmp Protocol? why mention http? 2)where do you want to use ping from? who checks who?
    the agent can check the availability of the any host using first parameter of icmpping[<target>,
    • Wolkenstein
      • Dec 2019
      1) Yes
      2) I use http for the response codes of my websites
      i got the problem fixed. My Datacenter Provider has a firewall rule, which icmp incoming forbids.
      Now i use an internal agent to ping different ips and it works as expected .
