Discovery states: Cannot create item: item with the same key
  • TheCookieMonster
    • Jul 2017
    • 48
    I have created a Discovery called Windows Disk Discovery, which uses a userparameter script to discover.
    Script:
    $drives = Get-WmiObject win32_PerfFormattedData_PerfDisk_PhysicalDisk | Where-Object { $_.name -ne "_Total" } | Select-Object Name
    $idx = 1
    Write-Host "{"
    Write-Host " `"data`":[`n"
    foreach ($perfDrives in $drives)
    $line = "{ `"{#DISKLETTER}`" : `"" + ($perfDrives.Name -replace '[^a-zA-Z]', '') + ":`" },"
    Write-Host $line
    if ($idx -lt $drives.Count)
    $line = "{ `"{#DISKNUMLET}`" : `"" + $perfDrives.Name + "`" },"
    Write-Host $line
    elseif ($idx -ge $drives.Count)
    $line = "{ `"{#DISKNUMLET}`" : `"" + $perfDrives.Name + "`" }"
    Write-Host $line
    $idx++;
    Write-Host
    Write-Host " ]"
    Write-Host "}"
    And this returns the correct information, for example:
    "data":[
    { "{#DISKLETTER}" : "C:" },
    { "{#DISKNUMLET}" : "0 C:" },
    { "{#DISKLETTER}" : "D:" },
    { "{#DISKNUMLET}" : "1 D:" },
    { "{#DISKLETTER}" : "E:" },
    { "{#DISKNUMLET}" : "2 E:" }
    Zabbix Server then creates all the required Items / triggers etc...
    But then next to the Discovery entry, I get the errors:
    Cannot create item: item with the same key "perf_counter["\PhysicalDisk({#DISKNUMLET})\% Disk Time",30]" already exists.
    Cannot create item: item with the same key "perf_counter["\PhysicalDisk({#DISKNUMLET})\Avg. Disk Queue Length",30]" already exists.
    Cannot create item: item with the same key "perf_counter["\PhysicalDisk({#DISKNUMLET})\Disk Read Bytes/sec",30]" already exists.
    Cannot create item: item with the same key "perf_counter["\PhysicalDisk({#DISKNUMLET})\Disk Reads/sec",30]" already exists.
    Cannot create item: item with the same key "perf_counter["\PhysicalDisk({#DISKNUMLET})\Disk Write Bytes/sec",30]" already exists.
    Cannot create item: item with the same key "perf_counter["\PhysicalDisk({#DISKNUMLET})\Disk Writes/sec",30]" already exists.
    Cannot create item: item with the same key "vfs.fs.size[{#DISKLETTER},pfree]" already exists.
    The Items prototypes in the discovery are:
    Can anyone see whats causing the errors?
