Hi at all,
I would like to extract some fields from a log record and create new items to record them.
Imagine that such a string arrives:
2019122215213800114001002
I would extract the first 14 characters (ddMMyyyyhhmmss) and insert them in the localtime and then extract 001 from the position 15-17 and insert them in the value of the item.
This would serve to check the status of a sensor (001) and hook it to the date and time of the event, simply to historically check at a given time how the sensor status was.
In this string there is also the status of another sensor .. is it possible to build a new item with the same procedure and insert the value of the second sensor?
In reality I get about 20 sensor states in a single string, but they are always in known positions.
item.sensore.1
20191222152138 value 001
item.sensore.2
20191222152138 value 002
This is because in a string (or record) of the log I get more states of sensors ...
Giorgio Biondi.
item.sensore.1
item.sensore.2
Giorgio Biondi.
