Host description in problems
  • iNg4Phah
    • May 2017
    • 13
    There is a nice feature: in the Monitoring>Latest data it is possible to display item description (zabbix_item.descr.png in the attachment). Is it possible to display a description of a host in Monitoring>Problems in the Host column similar to the item description?
  • Hamardaban
    • May 2019
    • 2714
    At the moment, this is not possible without reworking the source codes of the frontend.
    It's a good idea!
    • Hamardaban
      • May 2019
      • 2714
      After a little work with the frontend, I made the display of the host description in the list of problems.
      Changes one file - include/triggers.inc.php.
      Below the line in diff format:
      2284c2284
      <                       'output' => ['hostid', 'name', 'maintenanceid', 'maintenance_status', 'maintenance_type'],
      >             'output' => ['hostid', 'name', 'maintenanceid', 'maintenance_status', 'maintenance_type','description'],
      2371,2372c2371,2372
      >                       $trigger_hosts[] = ($host['description'] !== '') ? makeDescriptionIcon($host['description']) : null;
      For version 4.4.1
