Configuration import-how to overide a trigger with the same name and a new expression
  • mishta
    • Aug 2018
    I have previously configured a trigger named "A" with the expression "B > 1" (by import). Now i understand that that the expression was wrong and i would like to update it to be "B> 1 or C >2".
    When i import the new trigger with the name "A" and the expression "B> 1 or C >2". i get 2 triggers. How can i override the trigger to have only 1 trigger with the updated expression?
    i see that this issue was raised in 2008 (https://www.zabbix.com/forum/zabbix-...ion-is-changed) and back then there was no way to do it "straightforward" from the API. is there are way now? and if there is no way.
    how would you suggest to workaround it?
