7 Best Vacuums for Pet Hair
If you are a pet owner, then you know how important it is to vacuum frequently to collect the pet hair that accumulates quickly. Don’t worry, many other pet owners take this issue very seriously too, and want a reliable vacuum that not only can remove all the hair to keep the hair problem under control, but also make the otherwise tedious chore a walk in the park.
It can be challenging to find the best performing vacuum cleaner among a great deal of options out there. For your convenience and for pet owners everywhere, we have compiled a list of the best vacuum cleaners recommended for pet owners.
✫✫✫ Picked For You: The Most Expensive Vacuum Cleaner - Best vacuum cleaner in the world
#1- Shark APEX AZ1002 Duo Clean with Zero-M Anti-Hair Wrap Technology
The Shark is a brand known for its comprehensive catalog of household appliances; especially vacuum cleaners designed to be good performers in a specialized niche. It should come as no surprise that the Shark Apex AZ1002 will also be an extraordinary vacuum machine; it is a wonder for both pet hair as well as carpets and hardwood floors.
The true power of Shark Apex AZ1002 shines when it has to deal with hair stuck on your roller brush whether it be human hair or pet hair; it can remove them with a breeze thanks to its Zero-M system. This makes this vacuum cleaner a perfect match for large dog owners as it is the best vacuum for dog hair.
It also comes with a high-quality air filtering system to remove allergens and pet odor, and LED lights to tackle the dark corners easier. Additionally it is also noise proof as a bonus to avoid disturbing your lovely pets while you work on the cleaning duty. Remarkably this is the best pet hair vacuum for any home.
#2- Shark Rotator True Pet Powered Lift-Away NV752
An incorporated design combining many features at once will always be an attractive good buy for customers wanting a bit more versatility, and this 3-in-1 vacuum cleaner is sure to deliver.
Particularly, the three features this vacuum offers are a strong upright cleaner, a liftable pod with a roller brush underneath, and a canister equipped with a caddy very ideal for pet hair vacuuming. In fact, the efficiency of this design makes this the best vacuum cleaner for dog hair.
In addition to pet hair, this vacuum cleaner also incorporates technology to fight against annoying allergens.
It also comes equipped with LED lights and a little brush accessory that is motorized. These features come together to improve the versatility of the machine even further; the vacuum cleaner is not only efficient at cleaning pet hair but also efficient at cleaning dust on many different surfaces and in many deep corners.
#3- Dyson Ball Animal 2 Upright Vacuum Cleaner
Probably one of the harder to get vacuum cleaners out there on the market, but it is well worth the trouble to look for it.
At an affordable price you can get a vacuum cleaner with great maneuverability that can single-handedly clean your entire house in one go flexibly. You will literally never find it a hassle having to use this vacuum machine to clean. The vacuum also offers you a very nice warranty if you purchase it through licensed retailers.
A downside to this vacuum cleaner is that it does not get along well with stairs in spite of the mentioned phenomenal flexibility and maneuverability. But on the bright side, for every other house terrain this machine is a wild beast, picking up everything from dog hair on the carpet or cat hair on the cushions to tiny crumbs left on the kitchen floor. This is among the few options that is the best vacuum for cat hair.
➸➸➸ You Might Also Enjoy: What is the best vacuum cleaner - Top vacuum cleaner reviews
#4- Bissell 20431 Powerglide Lift Off Pet Plus Upright Bagless Vacuum
The reason why this Bissell pet hair eraser has made our list of the best vacuum cleaners for pet hair is because it is specifically designed to target pet hair in places often very difficult to clean such as stairs or upholstery. In addition, this vacuum cleaner also comes with a superb odor filtering system that will remove the bad pet smell from your home and leave you with completely fresh air.
Another reason why this is an ideal vacuum for pet owners is that it also comes with two additional components to assist you with removing pet hair. The first one is a strong turbo eraser that specializes in cleaning up long and thick pet hair quickly. The second one is a gentler tool specializing in deep cleaning the finer hair stuck to your fabrics around the house. This 2-in-1 design gives you great freedom switching between an upright and a handheld vacuum.
If that is not enough to convince you then the brush rolls it comes with that make quick work of any pet hair on any surface surely will.
#5- New Miele Complete C3 Cat & Dog Canister Vacuum
While this is not the most reasonably affordable option on this list when compared to the other options, it comes packed with quality ridiculously high enough so you don’t have to think about getting a new vacuum cleaner for at least 10 to 15 years to justify its premium price tag.
It features six different levels of suction power you can easily adjust with the foot pedal to suit all of your needs. The length of the wand is also adjustable, offering great flexibility. And while this is not a cordless option, the cord of this machine magically coils itself out of your way while you are vacuuming. Along with the standard vacuum cleaner you also get a brush for dusting, a crevice nozzle and an upholstery tool.
This vacuum machine can also eliminate pet odors and make quick work of picking up pet hair around your house.
#6- Shark Rocket True Pet HV382 Vacuum
Bearing the prestigious name of Shark, this vacuum cleaner surely does not disappoint. The first thing to note about this vacuum cleaner is its soft roller brush that can pick up both fine dust and large clumps of pet hair indiscriminately on both carpets and hard floors.
In addition, this vacuum cleaner gives you the flexibility of using it as a standard upright machine or as a handheld vacuum device by detaching the head, helping you tackle pet hair on a wide range of household surfaces. It also comes with accessories to help you make cleaning upholstery and underneath furniture a piece of cake.
Do be aware that the suction power of this vacuum cleaner is only average. Hence it will have trouble pulling up contaminants on carpets in one go and might require a few tries, and may have even more trouble with thicker carpets. And also be aware that it has trouble standing up while in the upright vacuum cleaner mode.
#7- Dyson V11 Animal Cordless Vacuum
Coming from the widely famous Dyson brand, the Dyson V11 will surely impress anyone who gives it a try.
Dyson is very famous for its legendary cyclone technology, which creates superb suction levels while consuming considerably less power. The newer system of the later generations is upgraded and adds to the concept of this inherently impressive technology which makes it the best stick vacuum for pet hair in the world.
This cordless stick vacuum comes with a digitally motorized roller brush designed specifically to powerfully remove stubborn pet hair from any household surfaces. Along with rough nylon bristles to clean even the toughest stains on the carpet and soft carbon filaments to catch the fine dust from the floor, this is a powerful machine that challenges all, earning itself another title of being the best cordless vacuum for pet hair.
When it comes to vacuum cleaners, then the Dyson brand has already grown to be synonymous with the best quality brand offering outstanding technology. You can be guaranteed that any product bought from Dyson will always be worth your money.
❖❖❖ Check Over Here:
Best Vacuum Cleaner In The WorldConclusion:
For pet owners, there is nothing sadder to hear than your friends and family refusing to pay you a visit because they fear being covered in pet hair. Hence choosing the right vacuum cleaner to solve this problem is very important, and we hope that you have found your best option from the list above.
