Key values
  • MichaelF
    • Feb 2019
    • 66
    Key values
    Hello!
    While learning the snmp discovery I've seen (both in the book and on the site) only the examples with discovering network interfaces and creating the interface item prototypes (Discovery rule: Key: snmp.interface.discovery and the item prototype: ifInOctets[{#IFDESCR}] / OID:IF-MIB::ifInOctets.{#SNMPINDEX}). But many Zabbix templates contain discovery rules for many other hardware: fans, psu etc, for example, the discovery rule - fan.discovery, psu.discovery, item prototypes: sensor.fan.status[swFanStatus.{#SNMPINDEX}], sensor.psu.status[swPowerStatus.{#SNMPINDEX}].
    The question: how can I know which keys may be used in the discovery rules and the item prototypes?
    Thank you in advance,
    Michael
  • Answer selected by MichaelF at 16-02-2026, 17:26.
    1berto
    • Sep 2018
    • 182
    I don't know if i understood you ...
    But have you checked the Discovery item on your template?
    • 1berto
      • Sep 2018
      • 182
      • MichaelF
        • Feb 2019
        • 66
        Sory for the delay...
        Thank you 1berto!
        • guntis_liepins
          • Oct 2025
          • 61
          If we are talking about low level discovery - all discovery rules supported by zabbix agent are documented under https://www.zabbix.com/documentation...s/zabbix_agent.
          Items used as for discovery are named *.discovery. Usually they receive JSON from agent.
          You can check what these rules return by using zabbix agent
          # zabbix_agent2 -t net.if.discovery
          net.if.discovery [s|[{"{#IFNAME}":"vetha0c08ca"},{"{#IFNAME}":"br-a3da5d0f6a8b"},{"{#IFNAME}":"veth0f4c96f"},{"{#IFN AME}":"docker0"},{"{#IFNAME}":"br-46138826b3d4"},{"{#IFNAME}":"br-b974bccd28be"},{"{#IFNAME}":"br-f0b94bc9fa89"},{"{#IFNAME}":"veth26dc8ab"},{"{#IFN AME}":"vethe69e59f"},{"{#IFNAME}":"br-cc0c3782c7bb"},{"{#IFNAME}":"br-74cd60776f6c"},{"{#IFNAME}":"eth0"},{"{#IFNAME}":" veth2bd39d6"},{"{#IFNAME}":"br-3131fe4ee93f"},{"{#IFNAME}":"vetheb613c6"},{"{#IFN AME}":"vethe05699a"},{"{#IFNAME}":"vethebe9c47"},{ "{#IFNAME}":"vetha32f860"},{"{#IFNAME}":"lo"}]]
          Some templates receive discovery via API calls - these are device specific.
          And you can create your own completely discovery rules as well.
