All Graph are Offset
  • Janus006
    • Dec 2019
    • 11
    Since a couple of days, all my graph are offset. Maybe after an update of OS, or maybe for nothing, I no not remember when it happened exactly. The clock of my server and of my client are Sync... (You can see on image)
    Any ideas ? I did not found anything on web
  • sancho
    • Mar 2015
    • 301
    Issue reported https://support.zabbix.com/browse/ZBX-17105
    • Grzegorz Wiktorowski
      Grzegorz Wiktorowski commented
      Thanks for the pointer. Today morning I've upgraded to 4.0.16 and started seeing the issue. I thought it was my environment specific.
    • Janus006
      Janus006 commented
      Thank you. My environment is not the issue. I will look for the new version correcting the problem.
