Zabbix dashboard running too slow hitting any things.?
  • pawan.linux@yahoo.in
    • Aug 2014
    Zabbix dashboard running everything slow. when i update anything here its taking time too long 2 to 10 minuts.
    Zabbix server is running Yes localhost:10051
    Number of hosts (monitored/not monitored/templates) 133 81 / 4 / 48
    Number of items (monitored/disabled/not supported) 17804 16446 / 3 / 1355
    Number of triggers (enabled/disabled) [problem/ok] 2438 2430 / 8 [80 / 2350]
    Number of users (online) 17 2
    Required server performance, new values per second 189.97
    performance, new values per second 133.28.
    anyone can i how can i solve this problem?
  • BDiE8VNy
    • Apr 2010
    • 680
    Try to identify the slow running queries, e.g. by enabling the debug mode for your user. The debug mode adds a new hyper-link 'Debug' in the top level menu, which reveals a lot of useful information.
    Then investigate why this or these queries are that slow. Thinkable reasons might be a sub-optimal configured/tuned database, resource shortage, bad execution plans or just a SQL query that should be made different.
      • Aug 2014
      Burst
      still not solve the problem and not seeing anything important there. when i hitting any tab still take too many times.
      history data 9 gb
      history_uint 7 gb
      trends 256 mb
      it should be not annoying for this.
      i didn't understand why this is happening.
