foundry/brocade/ruckus LAG utilization
  • metal
    • Nov 2019
    • 42
    I noticed that snSwIfStatsInBitsPerSec => brcdIp.1.1.3.3.5.1.48 and snSwIfStatsOutBitsPerSec => brcdIp.1.1.3.3.5.1.49 are available for physical ports only which shows the number of bits per second received/transmitted on the interface over a five-minute interval, I walked through them and it is only for physical interfaces. I searched in brcdIp MIB for the LAG stats, but could not find them. When looking at the switch configuration itself, it is possible to obtain both "300 second input rate" and "300 second output rate" for all physical interfaces or LAG interfaces using "sh int e x/x/x" or "sh int lag x", respectively. As long as the values exist in configuration, they should be on SNMP as well, I just can't find the correct MIB/OID for LAG interface stats i.e. utilization as for physical interfaces, add to this issue that walking through brcdIp.1.1.3.3.5.1.48/49 doesn't list LAG interfaces that are shown while walking through ifName/ifDescr/ifAlias OIDs, for example. I mean that I can see the LAG interfaces from ifName/ifDescr/ifAlias OIDs, but snSwIfStatsIn(Out)BitsPerSec only work for physical interfaces.
    Any input is appreciated.
    thanks
