Zabbix compiled agents for AIX 7.1
  • bpbeav
    • Jan 2020
    Noticed that there are no compiled Zabbix 4.4+ binaries for AIX 7.1 or later. Will you be posting any?
  • gofree
    • Dec 2017
    • 400
    you can safely use agents from v4 LTS ( v4.4 will be be obsolete anyway pretty soon )
    • bpbeav
      • Jan 2020
      Thank you for the quick reply - I've run into an issue with zabbix_sender producing semaphores on AIX7.1 machines and not cleaning them up. This post describes what I'm seeing, although it's a different server platform. https://www.zabbix.com/forum/zabbix-...-semaphore-use. I'm looking for a pre-compiled static zabbix_sender for AIX 7.1+ that includes the fix for this semaphore issue, and will try your suggestion.
      • bpbeav
        • Jan 2020
        Looks like the latest compiled AIX agent package that includes zabbix_sender which is posted on the Zabbix download sight contains the semaphore bug. Could someone post a static compiled agent package for AIX 7.1+ using the latest source to include the semaphore fix?
