Data Value Conversion
  • penguin356
    • Jan 2020
    I am working with a Cisco SG500. I need to monitor the switch ports POE usage. I am able to get the amount of current being supplied by the port. The switch is reporting in milliawatts (i.e 1600, 1700, 1800 etc). My template looks like this:
    <name>Port 01 POE Usage</name>
    <type>4</type>
    <snmp_community>{$SNMP_COMMUNITY}</snmp_community>
    <multiplier>0</multiplier>
    <snmp_oid>1.3.6.1.4.1.9.6.1.101.108.1.1.5.1.1</snmp_oid>
    <key>1.3.6.1.4.1.9.6.1.101.108.1.1.5.1.1</key>
    <delay>30</delay>
    <history>90</history>
    <trends>365</trends>
    <status>0</status>
    <value_type>3</value_type>
    <allowed_hosts/>
    <units>Watts</units>
    <delta>0</delta>
    <snmpv3_contextname/>
    <snmpv3_securityname/>
    <snmpv3_securitylevel>0</snmpv3_securitylevel>
    <snmpv3_authprotocol>0</snmpv3_authprotocol>
    <snmpv3_authpassphrase/>
    <snmpv3_privprotocol>0</snmpv3_privprotocol>
    <snmpv3_privpassphrase/>
    <formula></formula>
    <delay_flex/>
    <params/>
    <ipmi_sensor/>
    <data_type>0</data_type>
    <authtype>0</authtype>
    <username/>
    <password/>
    <publickey/>
    <privatekey/>
    <port/>
    <description/>
    <inventory_link>0</inventory_link>
    <applications>
    <application>
    <name>PoE</name>
    </application>
    </applications>
    <valuemap/>
    <logtimefmt/>
    </item>
    Zabbix is reporting back to me that the port is supplying KiloWats (KW) of power. I have tried changing the units to mW instead of Watts. All that does is append mW in front of Watts (it looks like this mWKWatts). Does any know how to get Zabbix to covert the integer value returned by snmp_oid 1.3.6.1.4.1.9.6.1.101.108.1.1.5.1.1 to Watts (i.e. 1.7W instead of 1700)?
    Thanks!
  • Markku
    • Sep 2018
    • 1786
    Hi, one way should be using a preprosessing multiplier of 0.001, and using float as the type information.
    Markku
    • penguin356
      • Jan 2020
      As a newb to Zabbix, any "how to" to do what you are mentioning would be very much appreciated.
      • Markku
        • Sep 2018
        • 1786
        In the item configuration page there is a Preprosessing tab on top. There add a preprosessing step, select Custom multiplier.
        Markku
        • penguin356
          • Jan 2020
          TY Markku!! I now have my POE Usage on the ports showing as Watts.
          Got another question...
          I am pulling the system temperature from my switch using SNMP OID 1.3.6.1.4.1.9.6.1.101.83.5.1.1.2.1. The system is returning the temperature in Celsius. I am trying to convert to Fahrenheit by using (C * 1.8 + 32). I have a custom multiplier (1.8) set on my item named SwitchTemperature. The custom multiplier is working perfectly.
          I have created another item named Temperature. This item is set to type calculated. The custom formula is this:
          (32+last("SwitchTemperature"))
          The item named Temperature is grayed out on the latest data page.
          Got any ideas on how to get the switch temperature to display on the latest data page in F?
          • penguin356
            • Jan 2020
            I figured it out!!!
            preprosessing via a java srcipt: return (value * 1.8) + 32
