Difference between 32bit and 64bit Agent
  • karel
    • Oct 2014
    Hello everyone,
    can anyone tell me the exact difference between a 32 bit agent of Zabbix and the 64 bit version ?
    So far i could find out that a 32 bit agent can run on a 64 bit operating system but sometime it could cause problems.
    Are there any features or optiones that are unavailable missing if i install the 32 bit agent on a 64 bit system or should i rather use directly the 64 bit agent for 64 bit os ? What do you recommend
    thanks in advance
  • tchjts1
    • May 2008
    • 1605
    32 bit agent on a 32 bit OS.
    64 bit agent on a 64 bit OS.
