"Host not found" and red availability flag
  • benkahla
    • Jan 2020
    Hello, I have a problem to monitor my virtual machines or make them available, I use the active agent zabbix, with a single passive element, zbx icon stays always red red
    Can anyone help me ??
  • 1berto
    • Sep 2018
    • 182
    1) Check the status and log of the agent (on the monitored host)
    2) Check the zabbix communication from zabbix server or proxy (zabbix_get) using your passive item
    • benkahla
      • Jan 2020
      zabbix agent work correctly and zabbix_proxy work correctly.
      i use zabbix proxy active mode to monitoring VMS , and i use template active agent zabbix fo vm on zabbix server , i have problem with icon zbx Availabilty , its grey !!
      • Hamardaban
        • May 2019
        • 2714
        From manual https://www.zabbix.com/documentation...guration/hosts
        "Note that active Zabbix agent items do not affect host availability."
        Which is basically predictable. The server does not have information about the active agent on the basis of which it can judge its availability. Getting data from an agent is a one-time event that doesn't say anything about availability at the next moment.
