Help with scaling graphs
  • barbaros
    • Aug 2010
    • 32
    Guys, I've noticed some small change in graphs scaling according to 2.0 version.
    This is situation from 2.4:
    This is something i had in 2.0 (this is simulated using fixed Y axis values):
    As you can see, the small changes are visible in 2.0, but not in 2.4. Is there a way I can change the scaling precision? In current situation, this is useless for me in many places. During this hour, there was no big peaks, but I believe you understand the idea.
    Similar behavior in Latest Data.
  • barbaros
    • Aug 2010
    • 32
    I believe, this is something similar to:
    So I have to wait:
    Fix Version/s: 2.0.14rc1, 2.2.8rc1, 2.4.2rc1, 2.5.0 (trunk)
