what application ( car mark ), process, ui is freezing ( engine, brakes are not working ) , what can by the way to access it zabbix agent, logs, api ( please open the trunk ) ...if you can please tell su more specifically waht app, problem, possible access to it
If the app is written by you-embed interaction with Zabbix in it. For example, sending its state to the Z server.
If the application can accept any external commands (for example, via the api) - check it by zabbix.
