Zabbix API how to know when a problem has been solved
  • Molusco
    • Dec 2019
    • 20
    Hi, Im using the zabbix api and getting events with trigger.get, every five minutes a crontab gets me the latest problems, Im going to use this data in a custom webpage, but I was wandering, how I can know if a problem has been solved, because if the problem is solved Im not going the get more data froma that triger.
  • exesition
    • Nov 2019
    • 121
    Use table event_recovery
    • Molusco
      • Dec 2019
      • 20
      splitek, I was currently filtering by value = 1, so what you are sugesting is that I bring the events with both values 0 and 1, and then compare them? with what value should I compare them? event id is unique? is not repeated in time for the same host, same type of event?
      • Molusco
        • Dec 2019
        • 20
        Thanks splitek, Why use the objectid? and not the eventid? they are not the same when event is triggered and when a event is solved?
        • Molusco
          • Dec 2019
          • 20
          Thanks splitek!
