Using message from SNMP Trap for Trigger name
  • Shahoff
    • Jan 2019
    • 21
    I do not want to bother much anyone. But I hope somebody can just give me a link to the topic/howto where this is already sorted.
    What I have:
    Zabbix 4.4
    SNMP Traps are configured.
    Sample Trap is:
    16:06:43 2020/01/22 ZBXTRAP x.x.x.x
    PDU INFO:
    notificationtype TRAP
    version 1
    receivedfrom UDP: [x.x.x.x]:38068->[y.y.y.y]:162
    errorstatus 0
    messageid 0
    community speed
    transactionid 13
    errorindex 0
    requestid 1226521381
    VARBINDS:
    DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (434401) 1:12:24.01
    SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMPv2-SMI::enterprises.1139.103.1.18.2.6
    SNMPv2-SMI::enterprises.1139.103.1.18.1.1 type=4 value=STRING: "spb"
    SNMPv2-SMI::enterprises.1139.103.1.18.1.2 type=4 value=STRING: "AlertServicesSnmpTest"
    SNMPv2-SMI::enterprises.1139.103.1.18.1.3 type=4 value=STRING: "14:100001"
    SNMPv2-SMI::enterprises.1139.103.1.18.1.4 type=4 value=STRING: "This is a test message to be sent in an SNMP trap."
    I want the message from the last string to be shown as "Problem" on dashboard. Currently my trigger expression is {TestHostname:snmptrap.fallback.strlen()}>1 just to raise the problem to the dashboard.
    Thank you in advance
    /Andrew
  • gert.derouck
    • Jan 2020
    • 69
    you could use the regsub item function:
    e.g. Trigger Name:
    Trap received: {{ITEM.VALUE}.regsub("1139\.103\.1\.18\.1\.4\stype =4\svalue=STRING:\s"(.*)"", "\1")}
    • Shahoff
      • Jan 2019
      • 21
      Thank you for respond.
      I modified regular expression to match the pattern and now I have my string in Group1 , but trigger name still returning entire trap. What exactly regsub doing here what is replacing ?
      • gert.derouck
        • Jan 2020
        • 69
        I don't understand exactly what you mean.
        Use following as the name of your trigger:
        • Shahoff
          • Jan 2019
          • 21
          Sorry for confusing , this is what the trigger name on dashboard looks like :
          Trap received:{11:20:32 2020/01/23 PDU INFO: notificationtype TRAP version 1 receivedfrom UDP: [x.x.x.x]:53103->[y.y.y.y]:162 errorstatus 0 messageid 0 community speed transactionid 20 errorindex 0 requestid 1481759497 VARBINDS: DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (363814) 1:00:38.14 SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMPv2-SMI::enterprises.1139.103.1.18.2.6 SNMPv2-SMI::enterprises.1139.103.1.18.1.1 type=4 value=STRING: "spb" SNMPv2-SMI::enterprises.1139.103.1.18.1.2 type=4 value=STRING: "AlertServicesSnmpTest" SNMPv2-SMI::enterprises.1139.103.1.18.1.3 type=4 value=STRING: "14:100001" SNMPv2-SMI::enterprises.1139.103.1.18.1.4 type=4 value=STRING: "This is a test message to be sent in an SNMP trap." perl callback function 0x55e39067c278 returns 1.regsub(1139\.103\.1\.18\.1\.4\stype=4\s*value=ST RING:\s"(.*)", "\1")}
          • gert.derouck
            • Jan 2020
            • 69
            Can you post a screenshot of your trigger config.
            • Shahoff
              • Jan 2019
              • 21
              Here it is: Click image for larger version
              • Shahoff
                • Jan 2019
                • 21
                Here is an alert​​​​​​​
                • gert.derouck
                  • Jan 2020
                  • 69
                  Ah. this forum tool is skipping some chars... There are some slashes lost:
                  Trap received: {{ITEM.VALUE}.regsub("1139\.103\.1\.18\.1\.4\stype=4\svalue=STRING:\s\"(.*)\"", "\1")}
                  • gert.derouck
                    • Jan 2020
                    • 69
Name:	Screen Shot 2020-01-23 at 13.17.17.png
                    • Shahoff
                      • Jan 2019
                      • 21
                      I used this site as well to fix regex , but trigger name is not working anyway
                      • gert.derouck
                        • Jan 2020
                        • 69
                        Bizar. I have several similar triggers configured in my setup..
                        Can you post your Trigger Name here as 'Code', since it's not completely visible in the screenshot.
                        Maybe insert a space after the colon (
                        Trap received:
                        ), although i don't think it matters.
                        • Shahoff
                          • Jan 2019
                          • 21
                          Reading here: https://www.zabbix.com/documentation...n/known_issues
                          And looks like double quote on my PHP is not working properly.
                          [root@db2-zibbexcore01 conf.d]# php -v
                          PHP 5.4.16 (cli) (built: Nov 1 2019 16:04:20)
                          Copyright (c) 1997-2013 The PHP Group
                          Zend Engine v2.4.0, Copyright (c) 1998-2013 Zend Technologies
                          Looks like I have to upgrade to v 7.x
                          Will keep you posted
                          • gert.derouck
                            gert.derouck commented
                            I have same version... and no issue...
                            # php -v
                            PHP 5.4.16 (cli) (built: Oct 29 2019 10:01:20)
                        • Shahoff
                          • Jan 2019
                          • 21
                          PHP 7.4 installed , but still the same issue
                          created python and perl scripts on 101regex and output of the file is good
                          root@db2-zibbexcore01 Downloads]# python test.py
                          Match 1 was found at 1422-1514: 1139.103.1.18.1.4 type=4 value=STRING: "This is a test message to be sent in an SNMP trap."
                          Group 1 found at 1463-1513: This is a test message to be sent in an SNMP trap.
                          So regex is working , something wrong with macro
                          • gert.derouck
                            did you escape the double quotes in your regex?
                        • Shahoff
                          • Jan 2019
                          • 21
                          #15
                          Standard escaping did not work, however \x22 worked !!!
                          So here is syntax: {{ITEM.VALUE}.regsub("\.4\stype=4\s*value=STRING:\ s\x22(.*)\x22", "Trap Received: \1")}
