Tomcat service monitoring
  • prejithprasannan
    • Jan 2020
    In my server Tomcat7 and 8 versions are running. I just want to monitor both versions of tomcat are running or not. If it is not triggering any alert. What item expression is used to fulfil this task. I used
    {Hostnameroc.num[tomcat7].last()}=0as Trigger expression. Its not working. Please suggest a possible solution for Item and trigger expression for monitoring Tomcat process.
  • Hamardaban
    • May 2019
    • 2714
    Look at the processes in the system - most likely you will not see the Tomcat process. Make monitoring of the java process !
    • tim.mooney
      • Dec 2012
      • 1432
      Originally posted by prejithprasannan
      I used
      {Hostname:proc.num[tomcat7].last()}=0
      The first argument to proc.num is the process name, the 2nd argument is the user the process is running as. If you're launching your tomcat processes via
      jsvc.exec
      , then you probably want something like
      {hostname:proc.num[jsvc.exec,tomcat7].last()}=0
      for your processes running as tomcat7 and
      {hostname:proc.num[jsvc.exec,tomcat8].last()}=0
      for your processes running as user tomcat8.
      Just checking whether the process exists is a start, but it's very basic and won't tell you if tomcat is healthy. You probably want to look at web scenarios to check that you can actually get tomcat to output the expected pages
      • tim.mooney
        • Dec 2012
        • 1432
        Originally posted by Arsoy
        Hi, I have a client that has a tomcat process that occasionally dies.
        If this is running on any recent Linux system, you should consider using a systemd service script to start tomcat, rather than a traditional init script. For all of its downsides, systemd excels at the "restart this if it died" issue.
        • prejithprasannan
          • Jan 2020
          jsvc.exec
          This is not working.
          Incorrect item key "proc.num[jsvc.exec,tomcat7]" provided for trigger expression on "hostname"
          • tim.mooney
            tim.mooney commented
            Did you edit the trigger without changing the item? You can't use a trigger if there's not a matching item somewhere.
        • prejithprasannan
          • Jan 2020
          This is possible in the sense of only one version of tomcat service is running on the server. If tomcat 7 and 8 are running on the same server we cannot identify that which tomcat version went down.
