Graphs not working over 400MB of traffic
  • ptera
    • Oct 2014
    • 109
    Can some one point me in the direction to fix graphs that struggle to display traffic above 500MB - Seems when traffic is below 400MB it works fine - between 400MB and 500MB the graph shows missing data points - over 500MB and graph displays the difference after subtracting 500MB from the total traffic.
  • ptera
    • Oct 2014
    • 109
    Here is the graph displayed
    • ptera
      • Oct 2014
      • 109
      Another related problem
      Not only does this mess up the graphs but it generates not a few events for each port on each device.
      Example...
      2014-10-31 14:31:08 .CET-BGP.ptera.net Interface GigabitEthernet0/1 Inbound Congestion Warning 26m 26s Yes (1) -
      2014-10-31 14:31:08 .CET-BGP.ptera.net Interface GigabitEthernet0/1 Inbound Congestion High 26m 26s Yes (1) -
      2014-10-31 14:28:08 .CET-BGP.ptera.net Interface GigabitEthernet0/2 Outbound Congestion Warning 29m 26s Yes (1) -
      2014-10-31 14:28:08 .CET-BGP.ptera.net Interface GigabitEthernet0/2 Outbound Congestion High 29m 26s Yes (1) -
      2014-10-31 14:25:08 .CET-BGP.ptera.net Interface GigabitEthernet0/2 Outbound Congestion OK Warning 3m Yes (1) -
      2014-10-31 14:25:08 .CET-BGP.ptera.net Interface GigabitEthernet0/2 Outbound Congestion OK High 3m Yes (1) -
      2014-10-31 14:25:08 .CET-BGP.ptera.net Interface GigabitEthernet0/1 Inbound Congestion OK Warning 6m Yes (1) -
      2014-10-31 14:24:08 .CET-BGP.ptera.net Interface GigabitEthernet0/1 Inbound Congestion OK High 7m Yes (1) -
      2014-10-31 14:23:08 .CET-BGP.ptera.net Interface GigabitEthernet0/2 Outbound Congestion PROBLEM Warning 2m Yes (1) -
      2014-10-31 14:23:08 .CET-BGP.ptera.net Interface GigabitEthernet0/2 Outbound Congestion PROBLEM High 2m Yes (1) -
      2014-10-31 14:23:08 .CET-BGP.ptera.net Interface GigabitEthernet0/1 Inbound Congestion PROBLEM Warning 2m Yes (1) -
      2014-10-31 14:23:08 .CET-BGP.ptera.net Interface GigabitEthernet0/1 Inbound Congestion PROBLEM High 1m Yes (1) -
      2014-10-31 14:22:08 .CET-BGP.ptera.net Interface GigabitEthernet0/2 Outbound Congestion OK Warning 1m Yes (1) -
      2014-10-31 14:22:08 .CET-BGP.ptera.net Interface GigabitEthernet0/2 Outbound Congestion OK High 1m Yes (1) -
      2014-10-31 14:22:08 .CET-BGP.ptera.net Interface GigabitEthernet0/1 Inbound Congestion OK Warning 1m Yes (1) -
      2014-10-31 14:22:08 .CET-BGP.ptera.net Interface GigabitEthernet0/1 Inbound Congestion OK High 1m Yes (1) -
      • ptera
        • Oct 2014
        • 109
        Really?
        No one using this software has links over 500MB?
        • kloczek
          • Jun 2006
          • 1771
          Are these counters used to calculate speed using delta per sec are read over SNMP? If yes. Are you using 32bit counters from ifInOctets/ifOutOctets OIDs from IF MIB or from the same MIB ifHCInOctets/ifHCOutOctets OIDs (64bit counters) ? Are you using SNMPv1 or SNMPv2?
          I have a hundredths even 10GB interfaces and I see on a lot of them much higher speed.
          You need to tell a little more what and how you are monitoring.
          • ptera
            • Oct 2014
            • 109
            So I am not sure I can answer all your questions since these were created from the Template SNMP Network Device Interfaces.
            The Application Item of the Template says SNMPv2 agent
            I looked around and could not find any place telling me about which counters are being used or how to change them.
            • kloczek
              • Jun 2006
              • 1771
              snmpget/snmpwalk output shows type of OID data.
              • ptera
                • Oct 2014
                • 109
                SNMPwalk
                Ok so I checked and the cisco is returning 32bit counters.
                So this is a no go?
                Funny how PRTG and Dude seem to work properly with these numbers.
                • ptera
                  • Oct 2014
                  • 109
                  That is a shame
                  I had hoped that this could replace our PRTG - bummer
                  • ptera
                    • Oct 2014
                    • 109
                    Money?
                    So is this one of things that we need to pay money to get fixed?
                    • aib
                      • Jan 2014
                      • 1615
                      Nope.
                      It means that you have to do something manually
                      1) Read the article from CISCO with explanation about 64bit counters.
                      http://www.cisco.com/c/en/us/support...mpcounter.html
                      2) Clone "Template SNMP Network Device Interfaces." to "Template SNMP Network Device 64bit Interfaces."
                      3) In new template go to Discovery Rules -> Network Interfaces -> Item Prototypes and change Keys for "Incoming traffic" and "Outgoing traffic"
                      old key: IF-MIB::ifInOctets.{#SNMPINDEX}
                      NEW KEY: IF-MIB::ifHCInOctets.{#SNMPINDEX}
                      4) Link new "Template SNMP Network Device 64bit Interfaces." to your Network device and let him create freshly discovered interfaces.
                      5) Keep an eye on new graphs for a couple of day and report back to the forum how it works.
                      Clear?
                      Sincerely yours,
                      Aleksey
                      • ptera
                        • Oct 2014
                        • 109
                        Clear
                        Everything was there to work with except I did have to look up how to disable version one snmp. Will report back after a couple of days for the long term results of the fix.
                        Thanks for the updated MIBs to use - I did not pay attention to In vs Out on the keys but figured that one out when my in and outs tracked together.
                        • ptera
                          • Oct 2014
                          • 109
                          In/Out Bound Congestion
                          These may be related to this same issue - I get Interface Congestion warnings for gig interfaces with only 200-300 M of traffic. Even using the Cloned template that now properly graphs the bandwidth usage.
                          Do I need to make a similar MIB change like we needed for the in/out keys?
                          • ptera
                            • Oct 2014
                            • 109
                            Money?
                            So is "this" one of things that we need to pay money to get fixed?
                            • ptera
                              • Oct 2014
                              • 109
                              #15
                              In/Out Bound Congestion trigger
                              8*{Template SNMP Network Device 64bit Interfaces:ifInOctets[{#SNMPVALUE}].last()}/{Template SNMP Network Device 64bit Interfaces:ifSpeed[{#SNMPVALUE}].last()}>0.8
                              This triggers warning and high on every interface even when it is not over 80%.
                              200M on a gig interface is not 80%
                              Is there anything that can be added to the Name of the trigger to get it to show the {Template SNMP Network Device 64bit Interfaces:ifInOctets[{#SNMPVALUE}].last()} in the name similar to how {HOST.NAME} displays the name of the host?
                              This would help in figuring out why the math for these interfaces does not work.
