I want to monitor a DCF77 USB Clock.
Bus 002 Device 002: ID 0403:e88a Future Technology Devices International, Ltd Expert mouseCLOCK USB II
For this I use ntpq -c cv:
I use the following userparameters to just pick up the NOMINAL and ILLEGAL DATE.
This gives me just the values. Now I'm trying to configure a trigger that fires whenenver the ILLEGAL values go up. Recovery should happen if the value goes down.
I tried the following:
But the trigger is just flapping.
What am I doing wrong here...
[root@gedaspl01 ~]# ntpq -c cv associd=0 status=0095 , 9 events, clk_bad_date, device="RAW DCF77 CODE (Expert mouseCLOCK USB v2.0)", timecode="?-", poll=1021, noreply=0, badformat=0, baddata=5, fudgetime1=425.000, stratum=0, refid=GUDE, flags=0, refclock_time="d7fa32a3.00000000 Tue, Oct 28 2014 15:20:03.000", refclock_status="TIME CODE; (LEAP INDICATION; ANTENNA)", refclock_format="RAW DCF77 Timecode", refclock_states="NOMINAL: 00:42:57 (3.94%); *ILLEGAL DATE: 17:25:09 (96.05%); running time: 18:08:06"
UserParameter=ntpq.refclocknom,ntpq -c cv | awk '/refclock_states/ {print $3}' | grep -o '[0-9.]\+'
UserParameter=ntpq.refclockill,ntpq -c cv | awk '/refclock_states/ {print $7}' | grep -o '[0-9.]\+
({TRIGGER.VALUE}=0&{Template_NTP:ntpq.refclockill.last(90)}>1) |({TRIGGER.VALUE}=1&{Template_NTP:ntpq.refclockill.last(90)}<1)
