How to change data collected from SNMP Agent
  • wegnix
    • Jan 2020
    I would like to know how I can modify a result collected from SNMP Agent.
    For exemple:
    Key: radioNormalizedMse
    SNMP OID: 1.3.6.1.4.1.3373.1103.80.12.1.5.1
    The result of this is:
    400
    I want to transform that value to 40.0
    I've tried to use calcullated type, but withou sucess too.
    If somebody can help me, would be great.
    Thanks in advance
  • gert.derouck
    • Jan 2020
    • 69
    Hi, you can configure a preprocessing step for the item: Custom multiplier. (Parameter: 0.1)
    For reference: https://www.zabbix.com/documentation..._preprocessing
    • wegnix
      • Jan 2020
      Thanks gert.derouck it worked fine.
