Query active problems
  • high-t
    • Dec 2014
    • 68
    Hi.
    I'm looking for a way of determining how many problems are currently active (not resolved).
    Didn't find such an item in the Zabbix Internal nor Zabbix Aggregate types of items. I would rather refrain from querying Zabbix DB directly, as future changes might alter the schema.
    Thank you in advance!
    Amit.
  • Markku
    • Sep 2018
    • 1784
    Hi, in that case you could build a script using Zabbix API to query the data you need. Then you can use a trapper item to store and graph that as you need.
    Markku
    • high-t
      • Dec 2014
      • 68
      Hmm.. interesting. So in a sense: have Zabbix query itself with an "external" script .
      I can do that NP.
      10X
      • ingus.vilnis
        • Mar 2014
        • 908
        I went the direct DB way since MySQL internal monitoring was already configured. Just added few user parameters on the DB server to be queried every minute.
        Zabbix - Number of Open Problems - Total
        UserParameter=zabbix.problems.open.total,HOME=/etc/zabbix mysql -N -e "USE zabbix; SELECT count(*) FROM problem WHERE source = 0 AND object = 0 AND r_eventid IS NULL;"
        And per each severity from 0 till 5.
        Zabbix - Number of Open Problems - 0 Not classified
        UserParameter=zabbix.problems.open[*],HOME=/etc/zabbix mysql -N -e "USE zabbix; SELECT count(*) FROM problem WHERE source = 0 AND object = 0 AND r_eventid IS NULL AND severity = $1;"
        Afterwards create a stacked graph and enjoy.
        And in case you wonder why you are seeing more problems in the graph that you would in the "Problems" page - the answer is in Dependent triggers.
        • high-t
          • Dec 2014
          • 68
          Thank you, ingus.vilnis for the idea. I did think of querying the DB, but I see two downsides for this approach:
          1. Schema is bound to changes as new versions becomes available.
          2. I need to be able to isolate problems associated with specific host group(s).
          The API approach offers solution to the above, so I went that path and have already wrote the script. It was no-brainer.
          Makes sense?
          • ingus.vilnis
            • Mar 2014
            • 908
            Sure. Glad you have a solution already.
