mitoring OFTP2 connections
  • dabbelju
    • Sep 2019
    Hi all,
    we are using Zabbix to monitor our OFTP2 connections. We do that by TCP connect to port 6619 which is basically fine.
    Due to the fact that it is just a TCP connect it will result in error messages in the log.
    Has someone implemented OFTP2 monitoring in Zabbix but with a script behind it which is simulating a OFTP2 session?
    Thanks a lot in advance.
    Dabbelju
