Prefered interface for template
  • gorekBoy
    • Jan 2020
    • 10
    Hi
    I've got few hosts with two SNMP interfaces. One interface is for OS monitoring and another for server hardware monitoring (e.g iLO, IMM2, iDRAC, ...) connections.
    I prepared templates for botch types of monitoring but some of them try connect to wrong interface.
    Is it possible to set preferred interface for template?
  • Hamardaban
    • May 2019
    • 2714
    When attaching a template, it takes the first interface of the desired type. After attaching the template, you can massively replace the interface with the one you want for all selected data items
