Alert when string value doesn't change for specific time period
  • ahahum
    • Jan 2009
    • 79
    I have a windows box that I'm trying to monitor a directory on to see when the last update to a file in the directory. I have a powershell script running that sends the last updated time of the most recent file to Zabbix using zabbix_sender. This is working fine and I see the values updating as they should.
    I don't know how to trigger on my condition properly. I need to trigger an alert when the value has not changed in x amount of time. I think this is possible, but I'm not too advanced on making triggers like this. Any help would be appreciated.
    Cheers!
  • LenR
    • Sep 2009
    • 1011
    If the string value is a "always increasing" date string, then it will never have the same value twice when it does change. In that case, then something like item.last(xm) = item.last() maybe
    • Semiadmin
      • Oct 2014
      • 1626
      I think in this case would be better convert time to unixtime in PS script and save it as an integer with unixtime as units.
      • ahahum
        • Jan 2009
        • 79
        Good feedback, thank you both.
        I have the values being entered as unixtime now and that should help achieve what I want
        I tried the one from LenR but it isn't clearing when the value changes. I'm trying out some recovery expressions, but I would've expected it to clear when the latest value does not match that of 2h ago according to my current trigger.
        • Markku
          • Sep 2018
          • 1784
          How about
          item.last() = item.last(,2h) (note the syntax, see https://www.zabbix.com/documentation...s?s%5B%5D=last)
          or
          item.min(2h) = item.max(2h)
          Markku
          • ahahum
            • Jan 2009
            • 79
            Originally posted by Markku
            How about
            or
            Markku
            Ah yes, that makes perfect sense and seems to be working. Thanks for your help, everyone!
