Monitoring meraki firewall active clients
  • carneirorf
    • Jan 2020
    I am configuring an http agent type item to monitor the number of active clients of the meraki firewall.
    However, the query through meraki API returns a lot of information about connected clients as an example below.
    "id": "kfdsfdab15",
    "mac": "d0:00:66:9f:00:2f",
    "description": "EST032-012",
    "ip": "199.167.1.92",
    "ip6": null,
    "user": "CN=Joana Perca Leite,OU=Usuarios,OU=Filial - 02,OU=Empresa,DC=empresa,DC=local",
    "firstSeen": "2020-01-14T06:52:03Z",
    "lastSeen": "2020-01-28T16:22:08Z",
    "manufacturer": "Dell",
    "os": "Windows 10",
    "recentDeviceSerial": "Q3PT-B7QZ-XV25",
    "recentDeviceName": "FL02-FW-01",
    "recentDeviceMac": "0c:8d:db:73:7e:a0",
    "ssid": null,
    "vlan": 0,
    "switchport": null,
    "usage": {
    "sent": 45215,
    "recv": 371069
    "status": "Online"
    I need to somehow filter this json output to count only the lines with the online status.
    curl -s --location --request GET "https://api.meraki.com/api/v0/networks/N_94849505912731083/clients?t86400=&perPage=200&startingAfter=1" --header "X-Cisco-Meraki-API-Key: $apikey" | jq . | grep "Online" | wc -l
    If I do the search via the command line with curl, as below, I can concatenate with grep to filter and wc -l to count, it's work fine, but how do I do it inside zabbix?
    The query is working well in zabbix, I just couldn't make the filter to count.
  • dilan bandara
    • Mar 2021
    Hi All,
    Currently, we are using zabbix 5.2.3 for the alerts monitoring, Also using meraki firewalls and its established with zabbix platform, so our concern is it's not generating any alerts for the WAN link up and down.
    Anyone have idea about this.
