Monitoring interfaces with SNMP
  • dhull
    • Aug 2014
    • 13
    I can't get interface information from an ASA. I've tried several templates but they don't seem to work. I installed the template "Template SNMP Network Device Interfaces". The device discovery rule isn't supported. Gives me an error message.
    ERROR
    snmp_parse_oid(): cannot parse OID "IF-MIB::ifDescr".
    Is there a fix for this?
    Thanks!
  • kloczek
    • Jun 2006
    • 1771
    ERROR
    Thanks!
    IF-MIB::ifDescr of is not OID containing the data or which you can monitor. It is vector of OIDs.
    Try to execute:
    snmpwalk -v2c -c<comminity_name> <dev.host.name> IF-MIB::ifDescr
    and you will see what you can use as OIDs.
    • dhull
      • Aug 2014
      • 13
      Installed SNMP MIBS
      Looks like I forgot a step when installing Zabbix. I remembered seeing something about SNMP MIBs for another monitoring system.
      1. Installed the SNMP MIBs downloader
      2. Downloaded and configured SNMP / MIBs
      3. Restarted services
      4. Everything Works!
      I've got bandwidth graphs for our ASA.
      • kloczek
        • Jun 2006
        • 1771
        IF MIB like many base MIBs comes with base net-snmp installation.
        If you are using Linux or other popular Unix you should be not forced to do above unless you are did something wrong before.
        • dhull
          • Aug 2014
          • 13
          Some of the MIBs aren't free
          I read somewhere that some of the MIBs are not free. I'm running Ubuntu 14.04. They don't include non free software.
          • Zarko
            • Jan 2015
            Same issue when running &quot;Template SNMP Device&quot;
            I came across the same issue with built-in template "Template SNMP Device".
            Running Zabbix 2.2.7 on Ubuntu 14.04.
            kloczek can you please explain a bit more how did you fix that problem?
            I installed snmp-mibs-downloader which downloaded quite a lot of MIBs, restarted zabbix server, but I still get the same error.
            Can you elaborate on "configured SNMP / MIBs" part?
            • renanmvc
              • Feb 2014
              • 12
              snmp_parse_oid(): cannot parse OID &quot;IF-MIB::ifAdminStatus.{#SNMPINDEX}&quot;
              estou tendo o mesmo probema:
              snmp_parse_oid(): cannot parse OID "IF-MIB::ifAdminStatus.{#SNMPINDEX}" - template do zabbix em um host configurado snmp
              quem conseguiu resolver me contate ou responda aqui, por favor!!
              uso o zabbix 3.0 no debian 7.0
              • danielrm
                • Jun 2016
                Solved
                Don't know what solved, but I installed the following packages (need to add extra and non-free in /etc/apt/sources.list
                snmp-mibs-downloader snmpsim unzip libsnmp-mib-compiler-perl
