How to add custom icon to maps
  • IMTV
    • Sep 2014
    Hi All,
    I'm currently new to zabbix, and am working on creating network maps using zabbix. I'm using zabbix v2.2.6
    I found zabbix default icon aren't quite exactly what I want. My question is, how can I import custom icons so I could use it in maps? what format should I use?
    Thank you, any help would be very much appreciated
  • Dommel
    • Oct 2014
    Really quite easy.
    Click the Admistration Tab
    Click on General Tab
    On the Drop down on the right hand side select Images
    Click on the Create icon button also on the right.
    • Sumo
      • Mar 2021
      Can I import images from Viscio?
