Tying triggers together with tags
  • HaveDill
    • Sep 2014
    • 103
    I have a variety of hosts that all have proper tagging on their triggers.
    The hosts that connect to the same locations, will all have their triggers fire if the external endpoint is down.
    Is there a way i can set either
    1. If you see multiple tags of the same exact value generated, produce less alerts
    or even
    2. Allow me to acknowledge / close in bulk from one eventid's acknowledge screen.
    Right now, because the tags are on different hosts, i am unable to bulk ack across the hosts from an acknowledge eventid url. You have to go to the zabbix problems page and check off each problem and then do a mass acknowledge
