How to monitor a process in zabbix?
  • RobertShook
    • Feb 2020
    I am using Zabbix4.0 and its working fine for service and system resources.
    Now i want to monitor some processes also using zabbix. I have tried the below combination in item but no success:
    Item:
    Type: Zabbix agent
    Key: proc.num[,,run,sidekiq]
    Type of information: Numeric(unasgined)
    Application: Processes
    Trigger:
    {HOST.NAME roc.num[,,run,sidekiq].last()}=0
    Below is the output of my ps -aux | grep sidekiq command:
    ab@xyz:~# ps -aux | grep sidekiq
    root 6595 0.0 0.0 14520 940 pts/0 S+ 10:10 0:00 grep --color=auto sidekiq
    ab 12332 0.1 5.3 885928 217508 ? Sl Mar14 8:50 sidekiq 4.2.7 abc [0 of 5 busy]
    ab 14756 0.2 13.3 1527376 539928 ? Sl Mar18 5:56 sidekiq 4.2.6 abc [0 of 10 busy]
    Can you please help me how we can monitor process? Because i need to monitor some other processes also like puma etc. LiteBlue
  • gert.derouck
    • Jan 2020
    • 69
    try using one of the following item keys:
    proc.num[sidekiq,ab]
    proc.num[,ab,,sidekiq]
    You can check the expected item values with zabbix_get.
    See also https://www.zabbix.com/documentation..._mem_num_notes
    Regards
