Request help to import MIB file of switch
  • digihe.mum
    • Feb 2020
    • 12
    how to import MIB files of Optilink switch
  • Markku
    • Sep 2018
    • 1784
    Hi, in practice, you don't. I mean, there is no feature in Zabbix that allows you to import the MIB file for any practical purpose. You need Zabbix templates instead.
    If the switch knows the usual standard MIBs, then you can start by using a ready-made generic template from https://git.zabbix.com/projects/ZBX/.../templates/net for example. Or you can try to find Optilink-specific template if someone has made and published one.
    Once you become familiar with a generic template, and if you have the vendor-specific MIBs, you can try cloning and extending a generic template for a richer vendor/model-specific template. In that case it is highly appreciated if those are shared in https://share.zabbix.com/ for example.
    Hope this helps.
    Markku
