sh: /bin/traceroute: Permission denied Cannot execute script on Zabbix Front End GUI
  • SaptariWijayaMulia
    • Feb 2020
    Hello all
    does anybody knows or familiar about this error message on Zabbix 4.4.5 fron end GUI ?
    • sh: /bin/traceroute: Permission denied
    • Cannot execute script
    • /bin/traceroute 127.0.0.1
    this problably because Selinux is enforcing, if I set it permissive there is no issue
    but I just want to know if we can resolved this without disable Selinux itself
  • tim.mooney
    • Dec 2012
    • 1436
    If you're going to run with SELinux set to "enforcing", you'll need to become familiar with how you use selinux commands to adjust its permissions and how you do things like grant a particular user the ability to execute commands labeled with a particular context. Because different monitoring environments have very different needs, it may be necessary to "customize" what Zabbix can execute or access (ports or files).
    I haven't checked the documentation, but are you certain that Zabbix supports being run in an SELinux environment?
    It looks like you might be able to use
    semanage permissive -a traceroute_t
    on your Zabbix server to allow anything tagged with the traceroute_t label to be in "permissive" mode. This doesn't completely disable "enforcing", but it does disable it for everything labeled with traceroute_t. That may not be what you want, and there may be a better way.
      • Feb 2020
      thank you tim.mooney
      the problem solved with
      # semanage permissive -a zabbix_t
      now i can detect os, traceroute, and ping from default zabbix gui script with the entire selinux enforcing mode
      • kronicklez
        • Mar 2025
        • 54
        If i'm use the zabbix appliances, may i know how do i can disable selinux so i can enable troceroute?
        Thanks and appreciate any feedback
