Database Monitor: Perform many SQL-queries. (For getting SQL Server errors)
  • Dmitry_V
    • Feb 2020
    Hi!
    Can I put many SQL commands?
    In this example, I encountered a problem.
    Task: Get a last database error from internal MS SQL procedure.
    1. I have a SQL-commands from Studio:
    2. Then I join all string to one with ";" delimiter:
    Declare @End Varchar(19) = (Select CONVERT(Varchar(19), GETDATE(), 120)); Declare @Start Varchar(19) = (Select CONVERT(Varchar(19), DATEADD(mi,-1,GETDATE()), 120)); Declare @Statement Nvarchar(100) = 'EXEC xp_readerrorlog 0, 1, N''Error'', null, '+'N'''+@Start+''''+','+'N'''+@End+''''; Declare @T Table (LogDate DateTime, ProcessInfo Char(64), Text Char(255)); Insert @T exec sp_executesql @Statement; SELECT ISNULL((Select TOP(1) Text from @T Where Text Not Like 'Error: 18456%'), 'No Error')
    and place it in file test.sql
    3. Test requests with isql:
    $ isql DSN DB_USER DB_PASS < test.sql
    | Connected!                            |
    | sql-statement                         |
    | help [tablename]                      |
    | quit                                  |
    SQL> Declare @End Varchar(19) = (Select CONVERT(Varchar(19), GETDATE(), 120)); Declare @Start Varchar(19) = (Select CONVERT(Varchar(19), DATEADD(mi,-1,GETDATE()), 120)); Declare @Statement Nvarchar(100) = 'EXEC xp_readerrorlog 0, 1, N''Error'', null, '+'N'''+@Start+''''+','+'N'''+@End+''''; Declare @T Table (LogDate DateTime, ProcessInfo Char(64), Text Char(255)); Insert @T exec sp_executesql @Statement; SELECT ISNULL((Select TOP(1) Text from @T Where Text Not Like 'Error: 18456%'), 'No Error') As Row1
    | Row1        |
    | No Error        |
    SQLRowCount returns 0
    1 rows fetched
    It works with isql!
    4. Create an item:
    5. And i have:
    - Status of item: Not supported
    - Info: SQL query returned empty result
    Zabbix server logs:
    36615:20200207:104235.653 error reason for "HOST:db.odbc.select[error_message,{HOST.HOST}]" changed: Cannot execute ODBC query: [SQL_NO_DATA]
    36601:20200207:104911.157 error reason for "HOST:db.odbc.select[error_message,{HOST.HOST}]" changed: SQL query returned empty result.
    36608:20200207:110411.050 error reason for "HOST:db.odbc.select[error_message,{HOST.HOST}]" changed: Cannot execute ODBC query: [SQL_NO_DATA]
    and so on
    Help please!
  • evgenys
    • Apr 2015
    Try to set: 'set nocount on' before your query..
    • lptarik
      • Oct 2021
      • 33
      I don't know why but i think only select queries work in zabbix
      • angelsc
        • Jul 2022
        Thanks a lot, this resolve a problem that i had with a query in mssql.
