"Host information was changed" doesn't go away
  • ddrucker
    • Feb 2019
    • 35
    Occasionally I get a "Host information was changed on somehost" which gets stuck. Normally these go away after 1 hour, but currently I have one that's been up for 13 hours. How can I get it to clear?
  • Markku
    • Sep 2018
    • 1784
    Hi, I'm assuming that the trigger stays activated because new values haven't been received for the item. Check that the agent is running properly.
    Otherwise, one way to remove the alert is to disable the trigger.
    Markku
    • ddrucker
      • Feb 2019
      • 35
      Must have been something like that - rebooting the zabbix server fixed the issue!
