recover mysql template for v 4.4
  • sksauer
    • Feb 2020
    Hi all,
    I just accidentally deleted the Template APP DB MySQL in version 4.4. I found an XML file but it is for version 4.2 and has errors on import. can anyone point me to a working xml file for version 4.4
    Thanks,
    Steve
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 152
    The XML file in the 4.4 source tree should work. You can download it directly from the source code repo: https://git.zabbix.com/projects/ZBX/...Frelease%2F4.4
    • sksauer
      • Feb 2020
      Glenco,
      Thanks. Just what I needed. Still learning where all the pieces are available. Zabbix replaced Zenoss and already found and fixed issues I never saw with zenoss. Zabbix rocks.
