Shared Memory Monitoring
  • Fotis
    • Sep 2014
    • 24
    Hello all,
    I would like to monitor shared memory on a windows server.
    I saw that there is vm.memory.size[shared] but unfortunately it's not
    supported for windows.
    Is there any value that I can use in a performance counter maybe?
    Can someone share his idea on how to do it?
    Cheers,
    Fotis
  • flako
    • Sep 2011
    • 40
    Originally posted by Fotis
    Hello all,
    The concept of memory 'share' is the unix.
    Not that windows does not have a share memory, just called different (manages memory differently).
    To do what you need you would have to read about perf_counter
    • Fotis
      • Sep 2014
      • 24
      Sorry Flako, but your answer wasn't very useful.
      If you read again my initial post, I already mention Performance Counters and actually I'm asking if there is any value that I can use..
      • flako
        • Sep 2011
        • 40
        mm, if it is useful to respond with a chewed response (resolved), as it is not useful ...
        If you look at the performance of windows or zabbix documentation of this reply. (sorry I will not do for you)
        If you want intelligent and useful responses, begins with http://www.catb.org/esr/faqs/smart-questions.html
        • Fotis
          • Sep 2014
          • 24
          I'm sorry but I can't understand your English.
          You don't have to be upset for not finding your answer useful.
          I didn't ask for a solution, I asked some ideas on how to do this.
          Cheers
          • aib
            • Jan 2014
            • 1615
            The short answer for your question, Fotis, is "NO"
            You cannot monitor "shared" memory on a windows server. (easily)
            There are no performance counter to control it or system tools to monitor it.
            But! The Best Guy in the Windows Monitoring world - Mark Russinovich - wrote the utility to monitor physical and virtual memory
            VMMap
            You can use it to control the virtual memory for the process and - if it have cli interface - you can use it to collect information in Zabbix Agent UserParameter.
            And, as I already said, it's not easy.
            Sorry
            Sincerely yours,
            Aleksey
            • Fotis
              • Sep 2014
              • 24
              Thank you Aleksey,
              I had a feeling that it won't be easy to do.
              I'll have a look on your suggestion and I hope that it will help me.
              Cheers,
              Fotis
