Proxy behind firewall
  • wjterveld
    • Oct 2019
    • 20
    Is it possible to have a proxy behind a firewall that only allows out going communication?
    So we can install a proxy inside that collects al info and sends this to the zabbix server (outside). I have installed this but Zabbix keeps telling me that the agent is unreachable for 5 minutes..
  • Hamardaban
    • May 2019
    • 2713
    The interaction of system components (server/proxy/agent) occurs over the TCP Protocol, which cannot work only in one direction - reverse traffic is required. But usually firewalls are able to maintain a session. Therefore, you should talk about which side starts the connection (who connects to whom). Your case is called "active proxy" and is described here: https://www.zabbix.com/documentation...toring/proxies
    • wjterveld
      • Oct 2019
      • 20
      Oke so if we need a environment where zabbix proxy makes an connection to the zabbix-server the proxy needs to be set to "Active Proxy"?
      this is the case for this customer but we still get "Zabbix agent on XXXXXXX is unreachable for 5 minutes"
      • Hamardaban
        • May 2019
        • 2713
        Yes. "Select the proxy mode. Active - the proxy will connect to the Zabbix server and request configuration data"
        • wjterveld
          • Oct 2019
          • 20
          oke in our case we did this but still Zabbix server reports the agent as "unreachable" ??
          from the proxy I can namp to our zabbix server on 10050 and 10051.. so there should not be a problem there...
          • Hamardaban
            • May 2019
            • 2713
            What type of agents do you use?
            Availability of the host is displayed. Four icons each represent a supported interface (Zabbix agent, SNMP, IPMI, JMX).
            The current status of the interface is displayed by the respective colour:
            Green - available
            Red - not available (upon mouseover, details of why the interface cannot be reached are displayed)
            Gray - unknown or not configured
            Note that active Zabbix agent items do not affect host availability.
            In the settings of network nodes it is specified that they work through a proxy?
            • wjterveld
              • Oct 2019
              • 20
              In the proxy config I have setup the Server= option to point to out zabbix servers.
              And in the agent (other server) I have setup the ServerActive= and Server= to the IP of the zabbixproxy server
              In Zabbix the proxy says last seen 7h ago and the none of the agents report back the state zbx snmp jmxi or pmi (I beleive it should be zbx)
              • wjterveld
                • Oct 2019
                • 20
                extra info:
                When I chekc the proxy log I see this error:
                cannot obtain configuration data from server at "xxx.xxx.xxx.xxx": empty string received
                cannot send proxy data to server at "xxx.xxx.xxx.xxx": connection is not allowed
                nmap xxx.xxx.xxx.xxx -p10050 tells me the port is open
                nmap xxx.xxx.xxx.xxx -p10051 tells me the port is open
                • Hamardaban
                  • May 2019
                  • 2713
                  Check this out
                  Host configuration
                  You can specify that an individual host should be monitored by a proxy in the host configuration form, using the Monitored by proxy field.
                  • wjterveld
                    • Oct 2019
                    • 20
                    yes this option is set to the proxy in question..
                    • Hamardaban
                      • May 2019
                      • 2713
                      Pls show me how the parameter "ProxyMode" is configured in Proxy.conf
                      and picture like this:
                      • Go to: Administration → Proxies
                      Do you use some kind of encryption between components?
                      • wjterveld
                        • Oct 2019
                        • 20
                        ProxyMode was left to default value.. #ProxyMode=0
                        • wjterveld
                          • Oct 2019
                          • 20
                          I think I see the problem.. Apparently the external IP adress can change from xxx.xxx.xxx.123 to xxx.xxx.xxx.124 and back!!! Is there a way Zabbix can deal with this?
                          I have added the second IP address in the proxy config also..
                          The proxy is now responding oke.. But the agents still do not report in as the should... Still the repsond as "unreachable"
                          • wjterveld
                            • Oct 2019
                            • 20
                            adding both IP addresses to the config made the proxy work. But the agents are still not reporting..
                            • Hamardaban
                              • May 2019
                              • 2713
                              #15
                              See the agent and proxy logs for errors
                              And as I wrote earlier-agents only with active data elements do not display their state
