problem to monitoring a switch d-link DES-3552P 48 ports
  • jvalenzuela
    • Feb 2020
    • 12
    I am having problems to monitoring a switch d-link DES-3552P 48 ports,
    Zabbix doesn't read more than 24 ports and also the CPU shows near 100% when if I see direct in the switch GUI console I saw no more than 30%
    any idea ?
    I am ausing the template Template Net D-Link DES_DGS Switch SNMPv2
    gracias
  • Hamardaban
    • May 2019
    • 2714
    Templates are a framework for building your monitoring systems. Understand what is written in it and how data elements are formed.
    If the request is made via snmp, setting the bulk option can help. If you are using snmpv3, the device may not have enough power to work with cryptography - switch to snmpv2.
    • jvalenzuela
      • Feb 2020
      • 12
      Hello, I am already using Bulk option :-(
      any other idea ?
      regards
      • Hamardaban
        Hamardaban commented
        The another part of my phrase was not mastered?
    • jvalenzuela
      • Feb 2020
      • 12
      we only are using snmp v2
      regards
      • jvalenzuela
        • Feb 2020
        • 12
        Solved was my mistake, wron IP :-(
        regards
