Change in trigger prototype not being seen
  • dthacker
    • Feb 2014
    • 42
    Goal:
    Change the trigger for less than 20% filesystem space free to severity "HIGH".
    I am using the template "Template OS Linux" which has the mounted filesystem discovery trigger prototypes set.
    I applied the template to a development system and then edited the template prototype for less than 20% free to severity "High" and saved.
    I then used fallocate to make one of the filesystems over 90% used.
    I'm not gettting any activated triggers.
    Do trigger prototypes actually work when attached through a template, or do I need to clone them to a separate trigger?
    Thanks!
    Dave
  • dthacker
    • Feb 2014
    • 42
    Replying to my own question. It must take awhile for the changes in the trigger to be reflected. I am now seeing an event for the host. Next problem is to get it to page me. But that's another topic
    Cheers!
    Dave
