Zabbix 4.4.5 VM on Hyper-V 2012R2
  • Alexey33
    • Feb 2020
    Created a virtual machine on Hyper-v 2012 r2.
    Installed the finished assembly on Ubuntu 18.
    It is possible to control through ssh, but when connected through a hypervisor, a black screen. This is normal?
  • provels
    • Apr 2020
    • 93
    Hi, Alexey33! (from XigmaNAS?) You probably found out by Googling, but I just did the same with the appliance version on 2012R2. I needed to toggle Alt-F2, -F3, -F4 until I found the active console on the VM's appliance. I also installed the Hyper-v template from https://share.zabbix.com/virtualizat...t-hyper-v-host to monitor the host and after a day of break/fix/break, I finally got it working. Also monitoring my pfSense FW with the pfSense template https://share.zabbix.com/network-appliances/pfsense-2-4. Lot of fun.
    OT, but do you know a good editor for Linux shell that works as well as WinSCP's GUI does for XigmaNAS? vi just stinks... Sure would be nice to have root access to edit files via WinSCP.
