Monitoring REST API requiring OAuth2 Bearer Tokens
  • yuri69
    • Feb 2019
    • 10
    Is there a way to monitor a REST API service secured by OAuth2 using Zabbix 4?
    Ideally the setup would look like this:
    1. Request Auth Token at an OAuth2 endpoint (basically a HTTP POST)
      1. send USER+PW, parse and save the token from the response
    2. Use the saved token and an API key to request data from the REST API endpoint
      1. send the token in a HTTP header and HTTP GET the data from endpoint
    3. Ensure the HTTP response is valid
      1. HTTP 200
    4. Parse the JSON response body and save the a specific parsed value as a Zabbix Item
      1. use JSONPath
    5. A Zabbix Trigger would use the Zabbix Item's value
    I've successfully created a Zabbix Web Scenario authenticating and checking the HTTP response code. However, I couldn't find a way to extract/parse the response JSON body.
    Any ideas, please?
  • valten
    • Mar 2020
    Did you find any success? I'm facing the same problem with inability to get response body.
    • yuri69
      • Feb 2019
      • 10
      Sadly, I did not. It feels like Zabbix is not the right tool for this kind of application level monitoring. Zabbix is kind of targeted at the infrastructure.
      • Avinasha
        • Jan 2018
        • 40
        This can be done Using Zabbix Web URL monitoring. You can run a HTTP POST with Username and password and Use a variable to grab the token response and use this variable in next step to authenticate it. Let me know if you want more details on this.
        • surya_99
          surya_99 commented
          Hi Avinasha, I've grab the token from HTTP Post but now how can we use token to authenticate in get http agent. Received token is working in curl command.
          curl -X GET "http://<WAF IP/Domain>:8000/restapi/v3/services?category=operational" -H "accept: application/json" -u "token:"
      • yuri69
        • Feb 2019
        • 10
        Do you mean https://www.zabbix.com/documentation...web_monitoring by By Web URL monitoring? If so, after the authentication I need to parse a value from the actual response body not just a HTTP status code.
        Parsing a non-trivial JSON payload to a Web Scenario Variable using regex doesn't seem right. In my case I need to parse the service response.
        • chok
          • Aug 2020
          I wanted to do the same. You can have further informations here : https://www.zabbix.com/documentation...toring/example
          • richard.ostrochovsky
            • Dec 2020
            Since ZBX 5.2, it is possible to implement this also using Script item: https://www.zabbix.com/documentation...emtypes/script, which has an advatage of being usable also in low level discovery (in comparison with web scenario). I am using it this way (with OAuth2 Bearer tokens).
            • Grumpyblade1994
              • Feb 2022
              How did you archieved this? I have a similar Problem with OAuth2. Can you explain this to me?
              • rahuls1436
                • Oct 2022
                yuri69 can you help me with step 5? I am able to prase access code to the jsonpath, now i am unable to figure out how to use the token in web scenario.
                • yuri69
                  • Feb 2019
                  • 10
                  Great, jsonpath is cool. Save the token as a variable in the Variables section of the Web Scenario Step. Then simply use the variable in a following Step of the Web Scenario.
                  For example, the token would be saved to a
                  {access_token}
                  variable in the first Step. Then use it as Name:
                  Authorization
                  and Value:
                  Bearer {access_token}
                  in the Headers section of the second Step. The second Step would simply require the 200 status code.
                  • kajaaj
                    • Mar 2024
                    Hi yuri69 , I followed your steps, buit it is not working for me. I have a token that is one year valid, so I only need to log in to a page with token to search for required string. Is this the correct way (see screenshots)?
                      Why bother with variables, if you can construct full header at once?
                      • kajaaj
                        kajaaj commented
                        Good point, thanks!
                    • kajaaj
                      • Mar 2024
                      yuri69 how did you manage to save the token in a variable in your first Step, to use it in your second Step?
                      I am trying to do this as is written here: https://www.zabbix.com/documentation...toring/example --> with regex:name="csrf-token" content="([0-9a-z]{16})"
                      But the problem is, that when I request for a token I only have an empty page with token which I have to save in variable, so I can not use regex:... as is stated above
                      My HTML Page with token, which I have to save as a variable to use it in 2. Step.
                      • Dwayne
                        Dwayne commented
                        you have a mix of case, I'm also not counting characters so make sure {16} is right if its range make that a range to suit
                        content="([0-9a-zA-Z]{16})"
                    • rdf.8888
                      • Nov 2022
                      I have the same issue, a need to do HTTP checks, I already have the token, but after one hour a need it a new token. It would be useful if a can push a new token on macro something like
                      {$TOKEN} = {?last(//baerer.token)}
                      Does anyone know how to solve that?
