Monitor a running Windows program
  • mch
    • Aug 2006
    I've a problem, I would like to monitor a running windows process, for example, cmd.exe (I want to monitor that this program is running)
    I've tried to add a trigger "{serverroc_cnt[cmd.exe].last(0)}<1"
    but it's appear to not work
    (sorry for my english)
    Thanks in advance
  • raminix
    • Jun 2006
    • 37
    Thanks in advance
    use "{serverroc.num[cmd.exe].last(0)}<1" instead for the windows agent.
    • mch
      • Aug 2006
      great, thank you very much it works...
      • jlackeyiii
        • Sep 2006
        Not sure of syntex
        I am new to zabbix I would also like to monitor a process to see how many times it is running. Not to sure of the syntex of the triger
