zabbix trap receiver don't translate mibs
  • alescri
    • May 2019
    • 32
    good morning,
    I have correctly configured the reception of traps,
    I added the mib in the mibs folder but if I receive a trap it is not translated
    SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMPv2-SMI::enterprises.231.7.2.1.21.2.3.0.20 SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.1 type=2 value=INTEGER: 1 SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.2 type=2 value=INTEGER: 0 SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.3 type=2 value=INTEGER: 0 SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.4 type=2 value=INTEGER: 2147465897 SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.5 type=4 value=STRING: "F5992" SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.6 type=4 value=STRING: "E8" SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.7 type=4 value=STRING: "IN SERV" SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.8 type=4 value=STRING: "BPB" SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.9 type=4 value=STRING: "CIRCUIT" SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.10 type=4 value=STRING: "LX ACTIVE S0" SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.11 type=4 value=STRING: "P203:1-01-003-000" SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.12 type=4 value=STRING: "01" SNMPv2-SMI::enterprises.231.7.2.1.3.1.1.13 type=4 value=STRING: "--" does anyone know how i could fix it?
    thank you
  • tim.mooney
    • Dec 2012
    • 1436
    Does your distribution automatically load all the MIB files from the mibs folder? The default config on the distro we're using (RHEL 7.x for our Zabbix server) doesn't appear to load any additional MIBs by default, so I had to add some config to get it to load the special MIB.
    What I ended up doing on RHEL 7.x was creating a
    /etc/snmp/snmp.local.conf
    and putting a line in that with
    mibs +My-MIB-Name
    (using 'mibfile' may have been better, but what I have seems to be working).
    According to the documentation I found (for RHEL), that file is used by both snmpd and snmptrapd for local overrides, so that's where I chose to specify the 'mibs' directive for our special MIB.
    • alescri
      • May 2019
      • 32
      mibs +My-MIB-Name
      it works!
      thank you,
      as distribution I use a centos and I thought it automatically loaded the mibs once in the folder.
      thank you very much now the traps are more understandable
      • tim.mooney
        • Dec 2012
        • 1436
        You're welcome, thanks for following up and confirming that resolved the issue.
        • ghaffar33
          • Jul 2023
          Im having the same issue, i already have a snmp.conf at /etc/snmp with the following contents
          mibdirs +/var/lib/snmp/mibs
          mibs +ALL
          at the above location var/lib/snmp/mibs i have all the mibs located in .txt format.
          But i dont get the translation. What more do i need to do​
          • tim.mooney
            tim.mooney commented
            The config you've shown looks fine. Have you restarted snmptrapd since you put that config in place?
            I would probably try enable logging and debugging, and then do something to generate a trap that your Zabbix server's snmptrapd should receive and translate, to see if there's any clue in the debug or log output that helps explain why snmptrapd is not honoring your settings.
        • ueuei
          • Mar 2023
          I got also this same problem, all configurations are in place, I also tried the snmp.local.conf solution but did not work.
          snmptranslate works really fine, only Zabbix is still showing OID in numeric form.
          What can I do next to solve this?​
          • skullbox15
            • Aug 2023
            I have the same issue. I'm using zabbix from the OVA. I have the traps coming in from a palo alto firewall:
            VARBINDS:
            DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (3812785368) 441 days, 7:04:13.68
            SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMPv2-SMI::enterprises.25461.2.1.3.2.0.1900
            SNMPv2-SMI::enterprises.25461.2.1.3.1.2 type=4 value=STRING: "2023/08/24 15:17:10"
            SNMPv2-SMI::enterprises.25461.2.1.3.1.3 type=4 value=STRING: "012001072398"
            SNMPv2-SMI::enterprises.25461.2.1.3.1.4 type=4 value=STRING: "SYSTEM"
            SNMPv2-SMI::enterprises.25461.2.1.3.1.5 type=4 value=STRING: "sslmgr"
            SNMPv2-SMI::enterprises.25461.2.1.3.1.7 type=4 value=""
            SNMPv2-SMI::enterprises.25461.2.1.3.1.8 type=70 value=Counter64: 7107212813705366132
            SNMPv2-SMI::enterprises.25461.2.1.3.1.9 type=4 value=STRING: "0x0"
            SNMPv2-SMI::enterprises.25461.2.1.3.1.12 type=4 value=STRING: "PA-820"
            SNMPv2-SMI::enterprises.25461.2.1.3.1.300 type=4 value=STRING: "sslmgr-config-p1-success"
            SNMPv2-SMI::enterprises.25461.2.1.3.1.301 type=4 value=""
            SNMPv2-SMI::enterprises.25461.2.1.3.1.302 type=4 value=STRING: "general"
            SNMPv2-SMI::enterprises.25461.2.1.3.1.303 type=2 value=INTEGER: 1
            SNMPv2-SMI::enterprises.25461.2.1.3.1.304 type=4 value=STRING: "SSLMGR daemon configuration load phase-1 succeeded."
            I downloaded the PA MIBs and have them in /usr/share/snmp/mibs/
            in my /etc/snmp/snmpd.conf I have an entry:
            mibdirs +/usr/share/snmp/mibs/
            mibs +ALL
            I restarted the services after adding. What am I missing here? I'm assuming I should see entries for the Palo Alto MIB files instead of "SNMPv2-SMI"​
            • skullbox15
              • Aug 2023
              does anyone know how to fix this?
                • 4970
                SNMPv2-SMI is so high level mib that it "contains" basically everything else... "enterprises" being one of its sub-branches for example..
                So everything is just fine...
                It is the purpose of this document, the Structure of Management Information Version 2 (SMIv2), to define that adapted subset, and to assign a set of associated administrative values. [STANDARDS-TRACK]
                • ueuei
                  • Mar 2023
                  Is it only snmptrapd to be restarted after configuration or any other service too? Because in case still the MIBs come in numerical format from Zabbix
                  (snmptranslate working fine instead)
                  • skullbox15
                    • Aug 2023
                    Sounds like I'm facing the same issue. I am able to get snmptranslate to work:
                    [root@appliance ~]# snmptranslate -m /usr/share/snmp/mibs/JUNIPER-MIB.txt -IR -On jnxFruFailed
                    .1.3.6.1.4.1.2636.4.1.9​
                    Am I correct in thinking with the proper MIB loaded I should get text that says "jnxFruFailed" instead of .1.3.6.1.4.1.2636.4.1.9 in the trap history through zabbix? My goal is to get rid of the OIDs and replace them with text so I can grab them with the API. I've got the API part working, I just need to get the OID translation part working.
