Trigger for certain network interface
  • korsar182
    • Feb 2020
    Is there any way to filter by #IFALIAS or network interface name in trigger expression?
  • Hamardaban
    • May 2019
    • 2714
    There is no such standard functionality, but you can create triggers for certain interfaces only if you use LLD. And It is most likely possible to use the API and create triggers from external scripts.
