Linux TCP port monitoring
  • mithunkk
    • Feb 2020
    Hello ,
    I am new zabbix user . Thanks Zabbix for wonderful NMS . everything is working fine in my newly developed zabbix. I have some linux based servers. In that servers few service is running in different port . I want to monitor that Port Status by Zabbix, either port is UP or DOWN. I have tired with creating item Type-simple check & Zabbix agent using key net.tcp.service[ssh,,22] . The open port like http,ssh is showing status,but have some services running in different port eg. 9990,3303 etc . But for those service nothing is showing
  • tim.mooney
    • Dec 2012
    • 1430
    Perhaps net.tcp.listen or net.tcp.port will work better for this?
    • mithunkk
      • Feb 2020
      Thanks ,
      i can resolved the problem creating new item using Type-Simple Check , Key - net.tcp.service[tcp,,Port_number] . Previously i made some mistake .Click image for larger version  Name:	linux tcp port.jpg Views:	0 Size:	61.2 KB ID:	396243
