Unable to make Zabbix Java Gateway work - How to troubleshoot?
  • myth0s
    • Jul 2014
    Hi!
    We are running Zabbix 2.2.7 stack. For some reasons, I am unable to use the java gateway.
    Zabbix Server
    IP: 10.128.64.13
    Packages:
    zabbix-server-mysql 1:2.2.7-1+trusty
    zabbix-frontend-php 1:2.2.5-1+trusty
    /etc/zabbix/zabbix_server.conf
    JavaGateway=10.0.54.47
    JavaGatewayPort=10052
    Port test to Java Gateway: nc -vz 10.0.54.47 10052
    Connection to 10.0.54.47 10052 port [tcp/*] succeeded!
    Zabbix Gateway
    IP: 10.0.54.47
    Packages:
    zabbix-java-gateway 1:2.2.7-1+precise
    /etc/zabbix/zabbix_java_gateway.conf
    all defaults
    /usr/sbin/zabbix_java/lib/logback.xml
    <root level="debug">
    Port test to Zabbix Agent: nc -vz 10.0.101.166 10055
    Connection to 10.0.101.166 10055 port [tcp/*] succeeded!
    Port test to JMX: nc -vz 10.0.101.166 11099
    Connection to 10.0.101.166 11099 port [tcp/*] succeeded!
    Zabbix Agent
    IP: 10.0.101.166
    Packages:
    zabbix-agent-2.2.7-1.el5
    /etc/zabbix/zabbix_agentd.conf
    EnableRemoteCommands=1
    LogFile=/var/log/zabbix/zabbix_agentd.log
    LogFileSize=50
    DebugLevel=4
    Timeout=10
    ServerActive=zabbix-srv.domain.com
    RefreshActiveChecks=60
    StartAgents=1
    Server=zabbix-srv.domain.com
    ListenPort=10055
    JVM has, among others jmx flags, -Dcom.sun.management.jmxremote.port=11099
    JMX is correctly configured on the JVM, I can connect to it from a remote host using JConsole.
    Host configuration in Zabbix FrontEnd
    JMX interfaces:
    IP 10.0.101.166
    Port 11099
    Item:
    Type: JMX agent
    Key: jmx["java.lang:type=Memory","HeapMemoryUsage.used"]
    Host interface: 10.0.101.166 : 11099
    Please note that the Zabbix Server cannot access 10.0.101.166 directly. All other items are of type "Zabbix agent (active)". These active items are working fine. For the JMX item, I expect Zabbix Server to query the Java Gateway, which will in turn query 10.0.101.166 over RMI.
    The Java Gateway log level is set to debug and I see *nothing* in /var/log/zabbix/zabbix_java_gateway.log.
  • myth0s
    • Jul 2014
    Solved - We had 0 java pollers.
