Advice - Zabbix Upgrading
  • the.monitor
    • Aug 2019
    • 22
    Hi all,
    I'm going to be running our upgrade from 3.2 to 4.0 within the next month and i'd like to ask for peoples experience on timescales.
    I understand from documentation that the database schema updates may take a considerable while.
    In terms of hardware;
    Zabbix is running on a Pacemaker cluster made up of 2x Dell R630s
    And our Zabbix Database is on a galera cluster ~600GB
    I'm monitoring ~32000 hosts
    How much downtime should I realistically be planing for?
  • HaveDill
    • Sep 2014
    • 103
    Honestly it depends on the upgrade...i had some in the past (v2.x) that took hours and hours with a ~1TB database. I've never had it take multiple days though. Check the zabbix server logs after teh upgrade, and you will see the % progress being logged.
    Make sure you update the webfront as well. Or you will get an error on the frontend stating the DB version is in a mismatch with it afterwards
